Display Rule Questions
I have two questions regarding display rules.
1) Is there a way to create a condition against all element types. i.e. text, dimension, circle, etc)
I only see a few like Line, Linestring, Mesh, and Shape.
2) I also see a wiki post that display rules aren't honored during an export to dwg. This I can understand since it is not supported in dwg.
However, Is there a way to change geometry while exporting to dwg honoring display rules. In other words, If I override an element from Color "0" and LS "0"
to Color "4" and dashed LS "2". When it is exported it is back to Color "0" and LS "0" or continuous. I want actual element to be Color 4 and dashed.
Link to export wiki
http://communities.bentley.com/products/microstation/w/microstation__wiki/23745.will-the-display-rules-be-honoured-when-exporting-to-dwg
Tom
