When importing data using a seed file line column line weights replicating the right side weights rather than between column weights
Seed
Imported using seed.
Hi DavidG,
Could you please elaborate a little more about what process are you following to import data using the seed file defined in the dgnlib?
Are you importing data using an XML file? if so, can you please send it for testing?
Maria
Maria Garcia
Grant
Yes it is a CE Table. After you create the table you can edit cell boundary properties. Its kind of flakey so you have to play with it a bit. I found it best to start on the inside and work your way out. I.E. First columns then title rows then headers and footers, then the final boundary. I set all of this up in a seed table and it replicates except additional column rows don't get set properly.
Grant, Sorry I miss read your message. Thought you were asking about line weights for cell. For fonts I'm using
http://communities.bentley.com/products/microstation/f/273/t/118717
