When importing data using a seed file line column line weights replicating the right side weights rather than between column weights
Seed
Imported using seed.
Unknown said:we were tired of translation errors and text getting bigger or smaller when it had to get re-mapped
Using vendor stick fonts between software packages has always been a pain. Thats why I switched everything over to Truetype Fonts some years ago. They are the same for all packages. Just starting using the Verdana Pro series. Its nice to get compress text without mucking around with the Height to Width ratios.
