CE - File New (Customise)
I want to be able to customize the File menu.  In V8i I use to add items to this File menu that linked to VBAs i.e.
File New (Model/Sheet),
File Print (A3)
File Print (PDF)
File Issue
I want to be able to do the same in CE.  Thus, the file menu needs to be customizable.  In the mock up below, I have shown some items I would normally setup for my clients.  Each of these will call up and load a VBA.  These tools save the clients a lot of time.  Hence I would like the same option in CE.  But not via the Quick Access toolsbar
Thank you
Ian
Parents Reply Children
