CE U1: Multi-snap icon missing from message fields
In CE U1, if you set e.g. Multi-snap1 as either the active or the default snap, does the icon go missing from the message fields?
Is it something I did or do others have the same result?
Multi-snap 2 and 3 are missing from the pop-up panel as active snaps, though they can be set as default snap.
Keyboard shortcut: +L, no idea how that's supposed to work really.
Much less how you're supposed to use the (MS1) tooltip you get hen you hover over the multi-snap 1 icon on that panel.
Is it just my machine or is this standard behavior for CE U1?
  • Hi Koert,
    I have tested what you described and yes once you make the Multi-Snap 1 active there is no icon in the message field, I see the same behaviors in SS4 and other V8i versions.
    Multi-Snap 1, Multi-snap2 and Multi-Snap 3 are the only icons that do not display in the message field in my case. I am also using windows 7, 64 bits. As you mentioned changing the text and icon size from Windows seems to solve the issue. I have created a wiki article here
    Regarding Multi-Snap 2 and 3 options these options are not available from the pop up panel directly as Multi- Snap 1, you have to use default snaps button instead to get these options.
    Maria
  • Yes Maria,
    the same bug is apparently also present in V8i SS4, maybe in other versions as well.
    Setting the Text and Icon size to 100% in Win7 64-bit, "solves" the problem in all versions I tested.
    Of course using 100% Text and Icon size isn't desirable in all cases. The multi-snap icons are the only ones that are affected by this phenomenon. So yes, I would expect to see the multi-snap icon at 125% text and icon size, just like I see them at 100%.
    I know I can activate multi-snap 2 as the default snap, however this is not convenient.
    A panel that requires 3 clicks to activate multi-snap 2, use that snap, and then another 3 clicks to activate multi-snap 1 again should only be used by people with too much time on their hands.
    With the button bar this process is just one click. Without button bar, in V8i it's 2 clicks, in CE 6 clicks, which is ridiculous.
    You should be able to add other snap modes to that pop-up panel, just like you can with the snaps toolbar.
    I don't see a way to customize that pop-up panel. Is it even possible?
  • Hi koert,
    I filed Defect 446088 in relation to Multi-Snap icons. I am going to create a SR and follow up with you.
    Maria
    Answer Verified By: Koert
  • Hi Koert,
    I was able to add these Multi-Snap options  using the Customize Quick  Access Toolbar (choose components from Toggle Buttons)
    See Screen shots
    This way you can have available these two Multi-Snaps
    Maria
Reply Children
