In CE U1, if you set e.g. Multi-snap1 as either the active or the default snap, does the icon go missing from the message fields?
Is it something I did or do others have the same result?
Multi-snap 2 and 3 are missing from the pop-up panel as active snaps, though they can be set as default snap.
Keyboard shortcut: +L, no idea how that's supposed to work really.
Much less how you're supposed to use the (MS1) tooltip you get hen you hover over the multi-snap 1 icon on that panel.
Is it just my machine or is this standard behavior for CE U1?
Hi koert, I filed Defect 446088 in relation to Multi-Snap icons. I am going to create a SR and follow up with you. Regards Maria
Answer Verified By: Koert
Hi Koert,
I was able to add these Multi-Snap options using the Customize Quick Access Toolbar (choose components from Toggle Buttons)
See Screen shots
This way you can have available these two Multi-Snaps
Maria
