usually I have my Properties Window docked right side of monitor thus open all the time.
I open Cell Library Dialog, select cell lib:C:\Programme\Bentley\MicroStation CONNECT Edition\MicroStation\Default\Cell\areapat.cel
When I then click on a cell Microstation hangs.It seems that it is taking VERY long for loading properties to show in the Proprties Window.When I close the Properites Window i can click on cells and everythings fine.
RegardsStephan
There have been many posts about the poor performance of MicroStation CONNECT. If you search this Forum, using MS_CELLLIST as a keyword, you can read the experiences of others.
MS_CELLLIST
