Hello.
There seems to be some mismatch between MicroStation (SS4) and my Network Locations.
I have a number of mapped drives but when I browse to This PC in MicroStation explorer some drives are missing and some drives are in the MicroStation explorer that are not in the windows explorer. Oddly enough, this is not the case with Bentley Geospatial Administrator (or any other program for that matter).
Any one who knows this problem and a solution maybe?
Bjorn Magnus Arnason
Stod ehf.
Which operating system are you using? In this thread communities.bentley.com/.../97823 there was a similar report be it against an earlier version of MicroStation. Try Going to Workspace > Preference > Look and Feel and turn off the option ' Use Windows File Open Dialogs ' close and reopen the file and then turn the option on again, does it help in your instance ?
Could also see if restoredefaults help, see http://communities.bentley.com/products/microstation/w/microstation__wiki/8671.restore-microstation-to-factory-defaults
