Hello all
I'll get straight to the point.
I have a 2D design model from which I drawn some lines, circles, dimensions and text.
I need this design to be scaled down and printed on an ISO A5 sheet of paper.
All of my annotations are drawn at 40mm x 40mm.
In order for my design to fit on an ISO A5 sheet of paper I need to scale my design down by a factor of 30.
The problem is that when i do this and print it the text and dimension values becomes too small to read because they are printed at 40mm / 30 = 1.3mm - which is too small.
My question is this, is there anyway of scaling my design down by 1:30 but scale the text size to about 3mm.
Below is a pic of my design.
Any help will be greatly appreciated.
Thank You.
You might want to take a look at the following blog that goes through the various ways you can use the different scales that can be applied.
http://communities.bentley.com/other/old_site_member_blogs/bentley_employees/b/mark_penns_blog/archive/2009/12/03/scales-in-microstation
Specifically Annotation Scale would be the most applicable in this case.
http://communities.bentley.com/other/old_site_member_blogs/bentley_employees/b/mark_penns_blog/archive/2009/11/23/usability-of-annotation-scale
There are several ways to do this now it looks like your working in the model space and not a sheet model..
If we assume that is the case and you want to do asap and as painlessly as possible
you can create new text style and new dimstyle that uses that named text style
so for the new text style you could call it 3mm 30 scale and set the text to be 90 x 90 mm with the same fonts and justification you already used, set it as the active text then select all your text and apply the new text style with the change text on a selection..
Then do the same for the dim style set the new dim style as the active style select all the dims and update to current dim style...
Then when you put a drawing sheet 30x ISO A5 over the top it will scale it self down via printer at 1/30 so text will be 90/30 = 3mm...
This is the old school way. it works and is quick but if you need to change it again to another scale then its rework as above again
Newer better more flexible method uses annotation scale and sheet models
Create a text styles ie dims , annotations, titles etc at a scale of 1 so in your case create text style 3 mm and set the annotation scale ON then change the design file scale to 1. then use/ create a sheet model attach your title block, then ref attach your model space to this at the scale necessary and have the annotation scale on and the text will scale accordingly .. I suggest you search for Mark penn blogg for annotation scale he does a much better job of explaining in detail ..
Lorys
For an existing drawing you can select text and text nodes using the selection tool.
Then Scale using About Element Center.
IN the future I would suggest getting up to speed on annotation scale.
I think the easiest way is to abandon your current saved view and set up the text the way it needs to be with text styles and annotation scale , or just change the text and dims the easy way I first mentioned then just reference the model into the sheet the saved view isnt really necessary, but if your set on using saved views you can make another new saved view with the new text setting.. but if you want to have several details and differing scales then using annotation scale is the only quick way, after you have set it all up it pays off.. but in your case you havent set it up it appears its just one drawing and you wont have multiple scales.. so just change the text globally then ref attach to the sheet..
A lot of drafters now days are doing things similar to autocad and dont dimension or annotate in the model space but do it all in sheet space instead of the model space there are pros and cons
the pros is its easy and you only need your text styles to suit your cad standards ie 1.8, 2.5, 3.5, 5 mm text for annotations, dims and headings so no text style scale factors.. with the dims msnt knows its a ref attachment and dimensions true to scale length and no annotation scale required for any thing...
Your sheet model is 1:1 and you ref in your model or saved views to the plot scale desired ie 1:30 etc
Con if you have to move the ref attachment , after you finished all the text etc, in order to fit it better or add more views details etc , then you have to move all your annotations and dims together the same amount and location, not difficult just a bother...
My personal preference is if your going to use sheet models then do all your text and dims in the sheet space...its a lot faster to do it last ...and is not scale dependant as the sheet is 1:1 so the text is 1:1 in mm and is now WYSIWYG
