The keyin TERRAINMODEL IMPORT LANDXML can be used to open the dialog for importing a landxml file. In V8i yo can also specify the name of the landxml file.
Example: terrainmodel import landxml I:\transit\eha\DGN\Test8.xml
This works fine in V8i but I can't make it work in MicroStation Connect - a dialog with the message "Invalide file" appears. If I manually select the same file everything works fine - this means that the file is OK. I've tried to replace the backslash'es with foreslash'es and I've tried to surround the filename with quotes (both single and double) but I still get the same error message.
What can I do to go on with this ?
TIA.
Regards, Evan
Answer Verified By: EvanH
