Is it possible to import Lidar files into Microstation V8i to bring ground levels through?
Hello, Could you specify the file format you are using? The ability to reference Point Cloud data in POD format is available in MicroStation. Other supported formats can be converted to POD file format before being attached. The Point Cloud tools can be found in: Tools>Point Clouds Regards Derval Canny.
Unknown said:Is there a way I can convert over to a 3D file model?
DGN file is a container. It contains on or more DGN models. A model can be 2D or 3D. Once a model is created, you can't convert it to a different dimensionality. A DGN file can contain both 2D and 3D models.
Create a new 3D model you can use for point cloud data. Attach your 2D model as a reference. That way, you don't have to change anything. You can keep your original 2D model and the 3D model in the same DGN file.
I would agree with Jon and would create a new 3D model and attach the POD file.
Could you specify the version of MicroStation (xx.xx.xx.xx) you are currently using?
The file formats that can be attached for conversion to POD format in MicroStation, are as follows:
Derval Canny.
Unknown said: Reference Attachments Create a new 3D model you can use for point cloud data. Attach your 2D model as a reference. That way, you don't have to change anything. You can keep your original 2D model and the 3D model in the same DGN file.
Or if I recall correctly you can Create a 3D model, attach point cloud, set clip volume or display depth if you want, and then reference that to your 2D model.
