Hi All,
If I am recalling correctly then the reset button on V7 used to let you get out of the current command and back to the waiting mode or at selecting stage. But I found out
in my version of V8i (8.11.09.608) the reset button won't allow me to do like it did previously even I assigned the reset button in the button assignments with "select none" but it still does not save it nor taking any effect. Is there another way to resolve this problem ?.
Pls. advise.
Thanks in advance,
Vincent
Hi Vincent, Can you try from Preferences menu-> Category: Input and select Allow ESC key to stop current command? Do also a File\Save setting and let us know if this works for you.
also review this link http://communities.bentley.com/products/microstation/f/19565/p/86933/244745#244745
Regards Maria
Maria Garcia
