I want to create a custom cell library, that contains the most commonly used cells. This will save a ton of time, and make it so all of our drafters don't have to search through the hundreds of cells that we use for every client. So what is the best way to do this?
Jeff Getch,
I assume you are just migrating Cells from multiple (larger) cell libraries into a single smaller Cell Library. As mentioned before, Cell Libraries are just DGN files. Cells are just models. So open the Cell Library, which you want to import Cell into. Then use the Import Models button on the top of the Models dialog to locate Cell Libraries / Cell which you want to import into the new Cell Library. The image below shows the process.
