[CE vs V8i] Update Sequence Config Variable
Did MS_REF_MASTERFILELAST_DESIGN change between CE and v8i or does the help menu have a typo?
From the help menu...
v8i...
MS_REF_MASTERFILELAST_SHEET
"Sheet Model Update Sequence"
Controls the default update sequence of references and master model in the sheet model. If 1, the default, the references are visible on top of the master sheet model.
MS_REF_MASTERFILELAST_DRAWING
"Drawing Model Update Sequence"
Controls the default update sequence of references and master model in the drawing model. If 1, the default, the references are visible on top of the master drawing model.
"Design Model Update Sequence"
Controls the default update sequence of references and master model in the design model. If 1, the default, the master design model is visible on top of the references.
CE...
MS_REF_MASTERFILELAST_DESIGN Design Model Update Sequence Controls the default update sequence of references and master model in the design model. If 0, the default, the master design model is visible on top of the references.
MS_REF_MASTERFILELAST_DRAWING Drawing Model Update Sequence Controls the default update sequence of references and master model in the drawing model. If 1, the default, the references are visible on top of the master drawing model.
MS_REF_MASTERFILELAST_SHEET Sheet Model Update Sequence Controls the default update sequence of references and master model in the sheet model. If 1, the default, the references are visible on top of the master sheet model.
