I installed amd activated Powerdraft on a desktop computer with Windows 7. I now want to activate the software on a laptop with Windows 10. It seems that I will not be allowed to do so. The trial period on the laptop is now over. Any suggestions please. Stoffel van Tonder.
Hi Stoffel,
I also recommend you to post your question in the Licensing and Activation Forum http://communities.bentley.com/products/licensing/f/275813#pi21629=1
and to also review this wiki article about activations in high security environments(basically the 4 point Manually activate as Administrator).
The wiki applies to MicroStation but the workflow is similar to MicroStation PowerDraft.
The licensetool.exe will be by default in C:\Program Files (86) \Bentley\MicroStation PowerDraft\PowerDrafthttp://communities.bentley.com/products/licensing/f/275813#pi21629=1
Important Note: If you contract is NON select and you have activated the license in the desktop computer via check out in order to activate in a different computer you need to do a check in of this license in order to keep license available. see image
Maria
