Looking for the Label line tool to add Bearing and distance to boundary lines.
Can not seem to find it.
I am using MicroStation V8i
You can find "Label Line" in the "Dimension Element" toolbox
you can also use the key in label line
ustn remembers the settings you last used so if you do it alot the keyin is good to have.. I like to run the tool with an F key...
Lorys
This is not bearing. That is angle and distance.
Change your Angle Readout settings...
* This thread is also really old, better to create a new one with your questions.
I did that. It turns out its a bug in ORD3.
