Looking for the Label line tool to add Bearing and distance to boundary lines.
Can not seem to find it.
I am using MicroStation V8i
Great...
MaryB
I don't have ord 3 but it does work in V8iss3-10 .. if you have set your read out to bearings , then after the line has been labelled by angle in ord , then get the properties of the line if it shows it as bearing then copy and edit).
Otherwise for now until ord is fixed do it in v8i ... only other alternative is to make a vba macro (seems a bit extreme) or an equation in excel to calculate bearing from angles relatively easy try google there are bound to be loads of free ones as lots of surveyors use these and share.....
Lorys
My Coordinate Readout matches what you have shown, but I only get N72°E. How do I get the label to read N72°02'36"E?
Dan
Dan Messerich, PLS
What software are you using, and which version of the software?
Where the format says "DD.DDDD" you can change that to DD°MM'SS"
In the dimension style dialog go to the Units tab. In the lower right corner are the settings for Angle Format. It is probably set at DD^MM". Change it to DD^MM'SS"
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
