I cannot set to 0.1 mils (1/1000 of inch)
as mentioned by Andrew, could you specify the version of MicroStation you are using (xx.xx.xx.xxx)?
I would also recommend that you take a look at:
Settings>Design File>Units
The units can be changed here.
Derval Canny.
hi Derval,
I set wu as this:
master unit: mils
sub unit: mils
accuracy: 0.123
then:
go to grid:
when I try to type in .1 for master grid, and 10 for reference
the software does not take
it always give me a number like:
3.9370
and there is a message said the field has to be that
I don't know why
