What is the correct way of setting up a txt file when trying to import coordinates?I have it set it up as follows but it fails on import with "Errror on imput file on lien 1, token 1!
5756.566; 7008.683
stuartw said: What is the correct way of setting up a txt file when trying to import coordinates?I have it set it up as follows but it fails on import with "Errror on imput file on lien 1, token 1! 5756.566; 7008.683
rename the extension of your text file to .csv, then open in excel
once in excel
the format should be
x y z in each column
when working in 3d files and if z not given use 0 for z
you cannot have headings in the excel file just raw coordinates you can now check for any strange things like commas or numbers not in separate columns
you can even add the 0's in the the 3rd column via excel auto fill..
now save again as csv after any edits ...
THen open the import coordiantes xyz tools under the dims misc I think .. you can always find with help and dock it to top border I use it alot so dont have to find it..
set your active settings to what you want and what you want ie cell or active pointext then set the tool to import the coord table, browse to the cv file and use the same choice format ie xyz you can even use a xyzT but you need extra column for the Text ie T
data point and wait for the magic... I think this is my favourite tool .... it will let you do survey type imports like trees as cells etc but I only do one type at a time for safety...bore holes is another good type...
Lorys
Another good way to import points is the pltpnt.ma tool. This also allows you to import the point names. You can download it here http://communities.bentley.com/products/microstation/m/microstation_gallery/270328
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
