Hi
I am very happy to see that we will now be able to import and use Revit RFA famiy parts in Microstation, and they are parametric! I did not see that coming. Has anyone had the time to test this yet. If yes, does it ( as promised in the usermanual) keep the variations ? I will also try find some free files and test this out in a few days.
Helge
RFA-FAMILY-VARIATIONSNOTWORKING.zip
Hi Marco,
Yep, i think its very good that RFA Familys can be used in MS! I did try out some RFA files that i found online today. My first impression is that the simpler once work, and the more advanced files loses the variations. All RFA files i tried kept the business data. I have ( hopefully ) attached some of the once that seems to be missing the variations, and one that did nor import.
Please test Update 3 where all the RFA files imported. Download link: MicroStation CONNECT Edition (Full) x64 Update 3 (English) - 10.03.00.30 Regards, Leonard Jones.
I have imported RFA Familys as parametric cells,But it's a pity that I can't modify it properties.
Can you give me some help solve this problem
Chunwei.Qin
