Hullo,
I have tried searching with google and havent had much luck.
Autocad has the ability similar to Excel to have a custom data field (eg. modifying a date data field from 05/28/1988 to 28/05/88 just by changing variables.
I would like to be able to have a data field that automatically uses the file name as the drawing number - but with out the guff at the end of the file name (eg. 1900-SS-S-0001 Control Plan R01 becomes within the paper space drawing number field 1900-SS-S-0001 )
I would also like to add a Revision Field that looks at the end of the file name.
Any help even if it is - "It cant be done" is appreciated.
I am not the best user of the forums.
John
Some links on Named Expressions...
A Step-by-Step Guide for Advanced Pen Table Text Substitution
Display active files last saved date and time in print border
Path and Design file name
Regards,Leonard Jones.
If it's always the first 14 characters of the FileName for the PlanName that's easy enough with Named Expressions. Start at position 0 and length=14 Expression: System.String.SubString(System.Path.GetFileName(ActiveFile.FileName),0,14) And the last 3 characters before the .dgn contain the Revision. for ......R01.dgn, should that Revision evaluate to R01, 01 or 1? Could a file named 1900-SS-S-0001 Control Plan.dgn exist? Or would the first version be named 1900-SS-S-0001 Control Plan R00.dgn or something else? What should ...R00.dgn evaluate to precisely?
If you want to go the VBA route, you'll first need to be very, very, clear on what you want that VBA to do to what elements and you'd probably be better of taking this to the MicroStation Programming forum.
