Sorry to say but I was under the impression Update 2 was going to be faster. Sadly its not.
I still have to remove the DGNWS files and the recent files to gain speed. This is with simple 2d files.
I have looked at the list of enhancements provided in this forum and none mention anything to do with this issue. I now have a long standing client that has stated they will NOT upgrade to CE, due to the speed, plus they will not sign up for Select on their next renewal date.
Ian
OK here is a snippet of my tests;
Software;
MS V8i SS3 08.11.09.459
MS CE 10.00.01.13 & 10.02.00.39.
Workspaces are networked to the same server
DGN file for the test is the same project and same file;
Project path; H:\PROJECT01\01 CAD\01 MODEL 2D\PLAN\
Project File; Plan Ground Floor Level.dgn NB. This is a 2D file
I have carried out a series of speed tests with V8i and various CE builds.
Open MS 3 times first thing in the morning (to MS manager)
V8i
CE
Open the same DGN as above path (this file is heavy in detail and contains 11 references files to nest depth of 2)
The workspace are very similar in structure
Workspace = Organisation
Workspaces = NA
Worksets = Projects
Users = Users
All tests were carried out at the same time of day, over a period of 30 mins.
Another client with the same workspace structure has speeds in excess of 60 seconds to open the files, compared to 5 seconds in V8i
As you can see CE is slower in all areas. It might not seem much but users do complain about its performance. In some cases it just freezes for 30 seconds and then jumps into life. I have asked Support t log this for me.
Could you please do the same test with files on local machine with Connection Client closed.
Turn OFF “Launch CONNECTION client every time I log into my computer.” and exit/close Connection client. Connection Client Options
If both the following issues are reproducible (consistent) then we will need to troubleshoot. We may have to collect some logs. I will get back to you on this.
Regards,Leonard Jones.
