I came across trying to use a WMS- source like:
"h t t p ://geo5.service24.rlp.de/wms/verwaltungsgrenzen_rp.fcgi"
If I add the server to the WMS Servers in Microstation/Powerdraft Raster-manager and open the source I get a wrongvalue for the bounding box and i can not save the connection to a xwms file. The buttons "SAVE, "SAVE and ATTACH" are greyed out as long I keep the standards limits settings.
The message bar of Microstation shows: "Bounding box wrong for WMS Map" message
Is there something new, since TR340554 (post: http://communities.bentley.com/products/microstation/f/19565/p/63762/213248#213248)
Or why do I have to set the limits to not using them?
Hi Frank,
Are you using CONNECT Update 2?
also could you please let me know what layer are you adding to the map in order to see the results?
I tried to insert all the different layers and I do not see same coordinates in north and south.
see the video:
Maria
Ok , I could reproduce the issue with Microstation SS4.
is this the same version you are using Frank? Please confirm and I will log a Defect for this issue on latest V8i version.
Answer Verified By: Frank Klein
Frank
Frank,
Can you try that attached settings? They seem to work and you do not get the Boundary box is invalid message.
https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/273/Frank_5F00_K.xwms
