Ok. I’m flying completely by the seat of my pants on this, no training in Connect Edition, but many years on MicroStation.
Trying to use ITEM TYPES as a replacement for TAGS
Again, this is just my take on how to use ITEM TYPES, but I am obviously doing something wrong. What is it?
Hi Mike, when you're editing via the Properties dialog, select the circle not the text. You can then edit the Bubble items.
Answer Verified By: Mike Francisco
[V8i SS4 08.11.09.829, BRCM, Promis-e, OpenPlant Modeler, OpenPlant PID, STAAD, RAM, ProSteel, InRoads, FlowMaster, Map, PondPack, StormCAD, Descartes]
Right Igna, Mike need to edit Circle > Items > Ibubble properties. I follow the workflow. Please check below image.
