Is it possible to assign the rotate top, front, side, and isometric view commands to keyboard shortcuts? So that a simple function key or CTRL + # will change the view orientation in a 3D model. Or, do you have any other tips for using the view rotation tool while 3D modeling?
Alex
When using Accudraw during your design workflow you have the Accudraw Shortcuts that allow you to Rotate by the various set definitions including Front, Left, Right etc. It also also shortcuts allowing to rotate by X, Y or Z, ACS, or even a rotate cycle. They can be found in the popup dialog by selecting the "?" on the keyboard while having Accudraw in focus.
Using RA (Rotate ACS) AccuDraw shortcut to rotate drawing plane
AskInga - AccuDraw Rocks
