Dear Microstation-Users I have a problem with the position of a raster. In DGN-Mode the raster with its frame is on the position that also is shown in the element information as origin. When I save the drawing as DWG or DXF the position of the frame differs in one direction with the amount of have a pixel, while the origin shown in elelment information is as in DGN-File. The txt-file shows the details/coordinates of the orthophoto, when it was calculated. The left-corner bottom of the raster should be X=0, Y= 437.2900. The size of the raster is 115.38mx28.45m, Pixels size 1 cm. What to do to get the image on the wanted position when saving as DWG/DXF?
Were you using the same units of resolution in your source DGN file as well as your DGN seed file you used for DWG Open? Check DWG Open Options which should tell you the DGN seed file you use. Set the UOR's to be the same as your source DGN file.
