Changing the weight of text in a note without affecting the leader weight
How do I change the weight of text in a note without changing the weight of the note leader? When we place notes we have the text at weight 2 and the leader and dimension line at weight 0. If I simply select the text and change the active weight to a different value, the weight of the note leader changes as well. See attached PDF for an example.
  • If you use the old Element Information dialog you can select the individual elements of the note and change their attributes. I have not been able to accomplish this with the new Element Information dialog or any other method. Maybe it can be accomplished through the Edit Dimension tools, but I don't feel that would be a valid method.
    Keyin- Analyze Element for the old Element Info dialog.
    Microstation CONNECT - 10.17.2.61
    ORD - 2021 R1 10.10.1.3
    ORD 2022 R1.1 - 10.11.3.2
    ORD 2022 R3 -  10.12.2.4
    ProjectWise - 10.0.3.453
  • When you place a note down, the elements are placed in two parts: the leader with the arrow and the text, which comes with the in-line leader attached. This is why the in-line leader changes weight along with the text, it is part of the text element. There are two ways to work around this.
    1) Change the dimension style and remove the in-line leader. You won't have the in-line leader anymore, but now you won't see that weight disconnect.
    2) Drop the note. The note will become text, a line element next to it, and then the dimension of the leader itself. You can then change the weight of the text to whatever you want and the in-line leader will not change because it has become disassociated. (NOTE: This will break the association of the note and the dimension will switch to a different linestyle (symbology) if you have that setting enabled in your preferences.)
    Cheers,
    Erik M.
