Tentative Snap not snapping to specific point even though Toggle AccuSnap is active
Toggle AccuSnap is active but when I click to activate Tentative Snap, the Snap icon disappears. The Tentative Snap command temporarily stops the Snap command so Tentative Snap is no snapping to the intersect location.
Maybe you have Snap Lock turn off:
In Ribbon or in Tool box:
José
You are correct, but now I am realizing that it may not be tentative snap but my snap lock is not working.
Here are my settings when I open MicroStation
I double click to activate and lock my Multi-Snap 3
Now I click on the line command
Notice the Multi-Snap 3 is no longer active
I have checked my Locks settings
I select the Multi-Snap 3
Note that the Mode does not display My selection but the Multi-Snap 3 is temporarily activated
If I select any single snap the Mode does lock in place
but when I double click Multi-Snap 1 or 3, the Mode goes blank.
Here are my settings when I open MicroSation
