Microstation v8i
Version: 8.11.09.459
All files opening as high priority as default. Unable to change files association to open with standard priority.
security.cfg has level set as "MS_SECURITY_LEVEL : NONE"
Unknown said:Locally saved files (when simply double clicking) are opening as 'High Priority'
That implies that the Windows file association is set to use the high-security switch when starting MIcroStation.
Unknown said:Files opened from ProjectWise are opening as 'High Priority'
That must be a PW setting.
Unknown said:There does not appear to be a separate executable in the microstation folder that would launch High Priority
There isn't a separate executable. If you look in the shortcut for High Security MicroStation (you'll find it in the Windows|Start|All Programs|Bentley menu), it's this:
"C:\Program Files ...\MicroStation\ustation.exe" -wsMS_SECURITY_LEVEL=HIGH
