DimNoteNotRendered.dgn
We have a customer file which contains a dimension with very large extents. I have attached the reduced test case which contains the dimension with entity id 48362. We found that this entity is not rendered in microstation. Please let us know why that dimension is not rendered in microstation. Is that dimension entity an invalid one? If yes, how to eliminate those entities?
Unknown said:We found that this entity is not rendered in MicroStation
Please identify the version of MicroStation, or other product such as PowerDraft, that you are using: MicroStation CONNECT or MicroStation V8i. What is the 8-digit version number (e.g. 10.xx.yy.zz) of MicroStation?
If you're using MicroStation in a ProjectWise (PW) managed environment, let us know that too.
I had your dimension examined by Development. It appears the issue with the dimension is due to second point for the dimension line designation. The first point appears to be okay, it is displayed in millimeters (master and sub units in the file are in millimeters) so translated to kilometers for readability the dimension would be (50km, 164km) this is far from you global origin but acceptable. The second point however is totally invalid and this is why it will not display and thus the dimension is not rendered. Also the large(and negative) value for height is a side effect of the second point being invalid. I am not sure how, and why the dimension was placed this way in the file but at this point your only alternative is to remove the invalid dimension using the "analyze element deletebyid" keyin as I previously suggested. Regards, Regie
