CONNECT update 2 Solid by Extrusion Along
Hi all,
I am trying out CONNECT update 2. When working with Solid by Extrusion Along Path I have noticed that it is not that powerfull then the legacy Solid by Extrusion Along. Simple extrusions are not made in CONNECT while in V8i it wasn't a problem. Does anyone else noticed this also? Or did I miss something?
And second: I really miss the legacy Profile is Circular option. Will this option come back? I don't want to switch between the legacy and parametric tools!
Best regards
Mark
