Hello to the Community.
I have a set of DGN files where I have to change the colors of the entities. These colors are coming from values of the standard MicroStation color table. I have to convert them to RGB mode that existing colors. I use Save As DGN but I can not indicate the RGB color correctly in the CSV files. Nothing is happening. Can you help me ? Thank you.
see if this works , I havent tried it yet...
select all element and change set to color by level but dont set the level..
make a dgn lib file with all the levels named and by level and set the colours you want to bylevel, then import the dgn lib library level and update all in the level manager if this worked then batch process for the others.. remember to set the level colours you want as the standard rgb .... in the dgn lib...
should work .. logically... seems right...
Lorys
Hi Lesbre,
thanks for providing more details! Unfortunately it creates a few more questions in my head ;-)
Let's forget for a minut csv remap tool and I'd like to make sure I understand your intention fully:
With regards,
Jan
