Hi
I accidentally set my left mouse click button to 'undo' every time you click it. Now, I cannot click on anything in Microstation. Is there any way to reset my mouse buttons to the default settings or do I need to re-install Microstation?
Thanks!
there is a microstation command line parameter without ms IMHO:
-restoredefaults
maybe it do the trick or delete your .UPF file in _USTN_HOMEROOT directory.
Frank
