Microstation version 08.11.09.714
Geopak Version 08.11.09.845
I received a file from our surveyor with embedded images/photos. The images were inserted as links from Project Explorer and the icon can be seen when the “markers” in view attributes is turned on. The links for the images are broken/invalid links. I believe the reason is that the path from the originator is different path that I have. I can edit/reattach the links for each image individually. Since all the folders are only in the same folder, I would like to know if there is a way I can re-path/reattach the links all at once.
