Placing Cells with Active Attributes
I am working in MicroStation SS3 08.11.09.714.
I have cells I am trying to place by level. The cell library is old and the elements are drawn on Level dsnCellElements and WT 1, CO 2, ST 0. Want to place the cells relative to the active level phoUtility, WT 0, CO 2, ST 0.
When the 'Relative' toggle is checked I can place the cell on the correct active level (phoUtility), but the WT is still on WT 1. How do I place the cells on 'By Level' (WT 0) with the Active Level attributes?
Dan
  • You will either place the Cell Relative and then change the cell to be By-Level using the Change Element Attributes but the Cell may use several Levels, and the Graphics in the Cell may not correspond to the levels you need them to be, so you will have to drop the cell, or go thru a tedious Element Properties changes. Other option is to Recreate the cell updating it to be By-level and on the proper levels. I would update the Cell as I need them, or in someone's down time change the cells. This falls apart if the Level Names change from Job-to-job.
    I Hope This Helps Someone Reading This!  (Intergraph>PseudoStation>MicroStation user since 1980's)
  • in the  bentley  library  utilities forum you will find  two cell utilities  on celltools and the  cell utility,  both are really usefull, so get both
    but one I forget  which one will place all the cells from any cell library in a matrix to fit a booklet into a dgn
    you can then drop all the cells  in selection set in a  booklet
    force them to be by level and turn them back into cells  with  old school method , attach cell library create fence , place origin and  create cell
    the  library can be  a new version name  of the  old  like V2... name .cell yes its one at a time  but  its quicker than you think....
     you can set the  levels and  colours how  you want  and work your way  logically thru each cell and  cross them out  after each one is recreated... once all done
    delete the old cell library and  rename the  new one to the old name  and move on to the  next book of cells. you can even share the task amongst your collegues....
    once your completely finished  re use the  tool to make a new  book (s) and batch pdf print them they will be very helpful in preview and documenting  your cells for the  whole office /company.... very helpful for setting up cad standards to specify which cells are in what lib and what they look like.. ie north points, scale bars, stamps etc...
    This tool is one of the  best tools I ever found at bentley  it can even create list and of course labels all the cells  by name, scale and library name....
    Lorys
    click link to PM me
  • Yes. The end goal is to place that cell on Level = PhoUtility, Color = 5 which is shown in the Elements Templates.
    The reason the Element Information shows "ByLevel (2)" is because that is how the cell was created in the cell library. (Level = Default, Color = ByLevel, St = 0, Weight = ByLevel).
    I can only get the cell to take on the Element Template's Level name when the cell is placed Relative with the Key-in "template active Photo Planimetrics\Cells\Utilities\Power Pole; place cell relative"
    Do you know what I'm missing to place that cell with my Element Template Attributes?
    Dan Messerich, PLS
  • so the "bylevel" color of the level that the cell is being placed on is going to be one color, and you want the cell to be a second color ?
    Timothy Hickman
    Main: 877 627 3772|
  • I want the cell, which contains a circle and 2 lines, to all be at color 5. The By Level color of 2 is for the rest of the utility cell to be placed at.
    We create all of our existing topo features at color green (CO=2) and the PP & luminaries at color cyan (CO=5) so the designer can see them better. The Utilities are on the same level so something doesn't get accidentally turned off and designed over.
    Dan Messerich, PLS
  • then I wouldn't be using by level settings or level overrides. The cell was created with a bylevel color, so simply setting the "active" color will not work.
    Timothy Hickman
    Main: 877 627 3772|
  • Dan
    If the cells were Point type cells instead of Graphic type, would that do what you want? They would take on the active attributes or the Template Attributes you want (Level, Color, Style, and Weight). What are you storing in a Graphic type cell you need to keep?
Reply Children
