test met parametric cells.dgn
Levels in parametric cells are better handled in CE U2 as we can make elements of cells invisible based on the level on which those elements were created.
But some things are still ambiguous.
Attached a dgn with parametric cells and a similar non-parametric cell.
All the bylevel attributes of elements within parametric cells are defined by the active level when the cell is created.
All the bylevel attributes of elements within similar 'normal cells' or 'shared cells' are defined by the level on which they were created.
I hope this can be corrected!
Luc Dierick
Currently the symbology information is stored in the parametric cell, if you drop the cell to a parametric solid the symbology will match to that which was originally defined. Though the symbology is known the cell is still treated as a single element when placed using the active attributes like any other element (line, circle, etc).
Defect 389082 was filed to address this issue.
5466.test met parametric cells.dgn
Working with levels in parametric cells is still not working as it should in Cu4.
Attached a file with one parametric cell.
All the bylevel attributes in this cell are not displayed correctly. For instance all lines should by continuous because the elements are on level "A10 binnenschrijnwerken" and the linestyle is defined as 'bylevel'. Bylevel linestyle for "A10 binnenschrijnwerken" is defined as continuous.
Can this please be corrected?
