Placing parametric cells UI
When placing parametric cells the UI is quite clumsy.
No possibility to use on active angle. No possibility to rotate or mirror while placing.
I think there is a lot of room for improvement here...
Luc Dierick
  • When placing a Parametric Cell while there are no tool options to place at an angle you can still place the cell at an angle using AccuDraw.
    The process would be:
    1. Pick the Parametric Cell you wish to place.
    2. Place focus on AccuDraw and put in Polar Coordinate mode.
    3. In AccuDraw set the angle to desired value and lock the angle
    4. Rotate the Accudraw compass to set angle by using Rotate Quick
    5. Place Cell as desired
    As far as mirroring you would have to use the mirror tool after placement. You
  • Nicely found David, but admit that it is not really user friendly. I still hope this can be made more straightforward.
    Luc Dierick
