I love the new section tool. It would like to get it so if I cut through a cabinet and I can see all the different materials that would display if you cut a real cabinet.
For example
The exterior may have a wood veneer but the cabinet is a plywood or particle board substrate and the doors may be solid wood.
Is there a way to set this up to display all the materials like this? Or perhaps replace the color fill with a material.
You can assign hatching or patterning parameters to each of your solids. When section graphics are generated by cutting those solids, the assigned hatching or patterning will be applied. Please refer the following thread for more details.
http://communities.bentley.com/Products/MicroStation/MicroStation_V8i/f/19565/t/12124.aspx
Sunand
Can you show me an example of this?
Kirk
I Wish Cadland was Reality
I posted an example dgn file in the afore-mentioned thread.
