The cell does not display the text properly if the text size has been modified after the cell has been placed.
Example, text size started at 0.15 originally. Modified to 5.0 via Element Properties... now when zooming out the text dissapears.
I have attached a sample DGN. Zoom in and out and you will see one of the text elements dissapear
bug.dgn
Seems that the Range of the one cell needs reset. If you type in Set Range and refresh your view you would see the Range square around the Modified After cell much smaller than the one Created Normal. You can reset the Range limits by selecting the elements and doing a Rotate Elements by Method = Active Angle and "About Element Center", having the Active Angle set to 0.000 deg.
PS: keying-in "Set Range" again will get rid of the Range Display.
When you edited the text size after it didn't change the Range of the text in the cell I don't know if that is a bug in Connect or just a user issue the way you changed them. Playing around it seemed to fix itself at times.
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
