I was trying to use a panel inside of the ribbon and I think I found an issue. In the panel, I have created five tasks and set the panel type to "Vertical":
The problem is that I now don't see all of the buttons. They drop off the edge of the bottom of the ribbon with no way to get to them...you can see that I can barely get to the fourth entry, but anything beyond isn't possible. Shouldn't there be a scroll bar or something? Also, is there a way for the label of the panel to display?
I believe I've uploaded the file...not sure if this worked...never have uploaded through the communities.deldot_menu.dgnlib
When set to vertical a panel is designed to hold 3 tools (if the size is set to small). If you require more than that it would be best to set it to Collapsible or OrderedWrap.
The difference between the two is Collapsible will fill a column up to 3 then create a new column. OrderedWrap will populate the tools into 2 rows.
