CE u2 Changing active cell takes 1-2 minutes.
Cell library is taking 1-2 minutes to change active cell via the Cell Library list.
The library is under 2 MB and has about 400 pipe fittings.
If I do this in a small file it only happens the first time I go to change a cell.  However if I'm in a similar file with an 11 GB point file attached it takes 1-2 minutes EVERY time I change cells.  If I key in the cell name using the place cell dialog it changes quickly.
Running CE u2 on Windows 10 w/12GB memory.  All files are local.
Parents Reply Children
