Cell library is taking 1-2 minutes to change active cell via the Cell Library list.
The library is under 2 MB and has about 400 pipe fittings.
If I do this in a small file it only happens the first time I go to change a cell. However if I'm in a similar file with an 11 GB point file attached it takes 1-2 minutes EVERY time I change cells. If I key in the cell name using the place cell dialog it changes quickly.
Running CE u2 on Windows 10 w/12GB memory. All files are local.
David, Although undefining the MS_CELLLIST works to stop the lag, this is a workaround rather than a solution, can you un-verify my post as a solution please. The MS_CELLLIST variable is quite important when it comes to creating standards and I would prefer Bentley to fix this, rather than think that we are all happy just not using it. Thanks
Unknown said:And don't use the variable in CE or V8i.
I didn't think I was using it either however it appears the default configuration sets paths for MS_CELLLIST. So you need to explicitly overrides the default paths and set it to null.
José
