I have been given a DTM file that I need to compare it to one I have created. How can I open it or import it into my MicroStation file.
I also am using Geopak.
Unknown said:I have been given a DTM file
What format (file extension) is the DTM file?
Unknown said:I also am using Geopak
There's a Forum dedicated to Civil applications. That would be a better place to post your question. GeoPak can, presumably, open more types of DTM file than plain old MicroStation.
For example the file extension *.DTM is used by Bentley InRoads for digital terrain models called surfaces in legacy INROADS V8i til SS3.The first four bytes of this kind of files will have the magic number hex'44 54 4d 0b ' so you can read "DTM" with a text editor for the first 3 bytes!
Frank
how to attach my .dtm file
