Ref Attachments - Item Types
Is there any way to attach Item Type Information to Ref attachments?
Simple use case:
I have a building with four floors.
Each floor has a core which is pretty much identical.
The user would attach the core model four times in the assembly/composition model at different z-elevations.
But ideally, he would also need to tag each Ref attachment with an Item Type... to allow each floor model to be recognised etc propertly.
I think that Item Types can be attached to cells, but most user would gravitate to Ref attachments for a lot of things.
