I am having trouble with patterns
If I run the verifydgn command I often get an error that looks like this
verifyPatternLinkage error: unsupported pattern modifiers bits 0x00481bb3 (unsupported=0x00400000)
If I run the repair dgn then some patterns may be deleted.
Unknown said: I am having trouble with patterns If I run the verifydgn command I often get an error that looks like this verifyPatternLinkage error: unsupported pattern modifiers bits 0x00481bb3 (unsupported=0x00400000) If I run the repair dgn then some patterns may be deleted.
I had similar problems at my last work place, I tracked it down to users ( me included) ref attaching DWG files to DGNs and copying through some acad patterns, and blocks etc with copy paste instead of converting the dwg first.... I was able to find and repair this via the axiom tools suite but I'm not sure how you fix this error without axiom.. it reported the ids and let me find by ids and delete the patterns and dead/ dud pattern definitions.. this can even happen with mstn pattern definitions that are no longer valid.. again without the axiom tools I cant fix it but this may help put you in the right direction....
Lorys
614-Jacks-Newark-606 DINING2 PULL.dgn
I have this issue with or without a dwg referenced. Typically I avoid dwg. If I do use a dwg file I convert it to dgn and then into a 2d file. Then I run axiom filefixer.
so what is a invalid mstn pattern definition?
Here is a sample file I just ran verify dgn on.
THe file is 614-jacks Newark 606 Dining2pull,dgn
Kirk
I Wish Cadland was Reality
Unknown said: (Please visit the site to view this file) I have this issue with or without a dwg referenced. Typically I avoid dwg. If I do use a dwg file I convert it to dgn and then into a 2d file. Then I run axiom filefixer. so what is a invalid mstn pattern definition? Here is a sample file I just ran verify dgn on. THe file is 614-jacks Newark 606 Dining2pull,dgn
so what did axiom file fixer tell you about this file?
why bother with verify when you have axiom tools available?
