Improper opening of DXF file
I have a problem with opening DXF files (city infrastructure map, water supply/sewage network) in Bentley View V8i. On one computer - and only there, all others workstations open the map correctly -  after opening the DXF the map looks like below picture (correct version can be seen on next picture).  Maybe it is a graphic driver problem?
