I have imported a shape file (from ESRI) into Microstation (not Bentley Map). This shape file includes some parcels (polygons) and their attributes. I can see the attributes of each polygon in Microstaion.
Question: How can I label polygons based on the attributes (e.g. name) in Microstation? I need all polygons to have their names labelled in the centre of polygons.
How can I do that in Microstation?
Frank
