I apologize but I'm not sure how to phrase my question.
Is there a line of text I can add to the PCF that will only list the files in File History for that project? I hope the image will help show what I mean. When I go to Microstation Manager to select a new project to work on, everything changes the way it should but when I look at the File History I see files from other projects I recently worked on. I am hoping to find something that will show only the File History of the project I chose. When I worked from home I made the User: the Project so when I chose the User I would change to the project folders and there I would only see recent files from that project.
I did sort of the same thing at this office. I created ucf's for V7, V8 and Autocad workmode. When I choose a different user I will only see files in that particular project.
I hope I was clear because as I reread this it sounds a little convoluted.
Thank you
Unknown said:Is there a line of text I can add to the PCF that will only list the files in File History for that project?
The recent File History is stored in your user preference file (*.upf), which is named after the user configuration file (*.ucf). The project configuration file (*.pcf) is unrelated.
Unknown said:When I worked from home I made the User: the Project so when I chose the User I would change to the project folders and there I would only see recent files from that project
In that situation the UPF reflects the project, because the UCF defines the project. However, you're still free to browse for files outside the project folders. I suspect it's your own working discipline at home that has stopped non-project files appearing in your File History.
In a normal MicroStation/Windows environment, users expect to be able to browse anywhere for a file. Consequently, those files appear in the File History stored in that user's UPF. If you want to prevent users from browsing outside the project folders, you need to implement a document management system (DMS).
