I am currently modeling a 3D mechanical arm using microstation v8i (select series 3). After many trials I still fail to constrain the individual
components to allow relevant mechanical motions/kinematics between the different components. I just need to know if it is possible to
to constrain 3D models that permit mechanical movements(swivel, slide, rotate and etc) on microstation
Carl Myhill
Technical Support Engineer
Bentley Systems
