Good Morning,
I am creating drainage areas using a dashed linestyle and I am having issues with my overlapping lines. I would like to keep my shapes for easier calculations, but anywhere the shapes overlap the lines are coming out solid. In ACAD as ong as the vertices match, the lines show up correctly, which does not seem to be the case in MS. Is there a setting or tool I can use that will allow me to keep my shapes while also showing the lines as dashed?
Frank
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
Answer Verified By: Michael Massengale
